Hotrodders Bulletin Board
#1
Spark plugs + HEI
I just replaced a point type distributor into a 307 CI. which has 13mm plugs, what type, gap, and brand is everyone using. This is a stock 307 chevy with a 3 sp. in a 61 Bel-air
#2
I ran AC R45TS plugs in my '72 307 motor. If your heads have tapered spark plug seats you can use the above plugs. I don't see a problem with running them with the HEI. Maybe the gap can be slightly larger w/ HEI.
#3
Open your plug gap to .045 for the HEI.
You made sure that your HEI had 12 volrs going to it, right? |
#4
For lower compression you can probably run up to .055", but there is no need. Voltage will be fine anywhere from .040 to .055. I personally gap mine to .045"
#5
10-4 on the 14 AWG from the distributor to the switched side of the fuse block
. I will be off to Pimp Boys tomorrow to look for some AC R45TS or maybe some Dinso U-Grove or anything i can fine that is in the heat range of a R45. By the way is a 43 hotter or colder plug? |
#6
The higher the number, the hotter it is.
#7
Doc here,
Don't forget to upgrade your Plug wires to an 8 or 8.5 Spiral core wires from the stock wires..or you'll have misfires, cross fires and RFI like a big Dawg.. Also assuming you removed the Ballast wire / Resistor from the circuit..else it will run like a muni bus if at all Doc ![]()
Aftermarket Solutions Electronic & Electrical Innovations |
#8
Thanks all , yes I have rewired the HEI straight to the fuse box (Switched) and the wires were off of a running Camaro the same place I removed the distributor from.
Back to top |
Similar Threads for: "Spark plugs + HEI"
| Chevy 454 Spark Plugs Selection Help | leejoy | Engine | 12 | 10-01-2006 11:05 PM |
| motor wont start spark plugs have oil on them | 54chevy22 | Engine | 3 | 09-11-2006 05:59 AM |
| motor wont start spark plugs have oil on them | 54chevy22 | Engine | 13 | 08-10-2006 08:28 AM |
| HELP! spark jumping from wires to the plugs like crazy (long post)!!!!!!!! | Blown72Camaro | Engine | 8 | 06-22-2004 07:01 PM |
| Spark plugs sparking to the side | mar10 | Electrical | 3 | 07-25-2002 04:51 PM |
