sparkplug diagnosis - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2010, 12:05 PM
sparkplug diagnosis
I have read here on an old post that if the top[head side]of the sparkplug is black and the bottom of the plug[piston side] is light, that this is an indication of oil coming in from the top,i.e. valve guides,intake leak etc. Am I correct in this assumption?
dave
Old 10-23-2010, 03:48 PM
what exactly do you mean by top side of the plug? best way to tell if your burning oil is to check and see how fast your using oil. is the engine going through a lot of oil without leaking it on the ground? any hints of blue smoke while its running? blue smoke on acceleration and all around is usually piston rings where blue smoke on deceleration is usually valve related from what ive seen. if your not using a lot of oil and its not noticable in the exhaust gasses youed be better off prolly just leaving it alone imo
Sparkplug has white curosive on it! Bucketwrench Engine 1 10-25-2009 02:50 AM
Champion Sparkplug Quality and a couple of questions Argess Engine 17 09-18-2009 09:40 PM
Engine knock diagnosis advice... Tyroma Engine 5 09-04-2009 11:36 PM
TH 350 throttle valve diagnosis help JonRunaas Transmission - Rearend 5 07-03-2008 10:15 AM
sparkplug indexing runn141 Engine 7 09-16-2006 07:00 AM
