Sparkplug wire resistance - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2004, 10:43 AM
vegahigh's Avatar
How can you tell if plug wires wires are marginally bad, and how do they fail.
I have a 350 SBC, MSD6AL with Taylor wires, MSD distributor, ( New cap and rotor). I recently re-crimped ends on to the wires, and have a few wires with 3x as much resistance as the others.
The engine misses over 4000 rpm, I have replace the cam, plugs, adjusted the valves and in general am running out of clues. By the way, carb is a Barry Grant 850, bigger than I would like, but I don't thinks this is the cause of my high rpm miss.
Is there an acceptable range of resistance for "Good" wires?
Thanks for the help
Old 09-29-2004, 11:02 AM
Jmark's Avatar
Rule of thumb is 1000 to 4000 ohms per foot of wire.
Old 09-29-2004, 11:09 AM
bullheimer's Avatar
NEVER use credit cards!
that would explain why my ohm meter always measured infinity. never could figure that out. guess i shouldnt be measuring with a digital multi meter.
Old 09-29-2004, 12:37 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
The better made wire is 100 or less, the new Moroso is 40 OHM per ft. , is the best on the market today. Good Mallory wires are 50 OHMs. You will not get a reading if the wire is burnt.
The lower the OHM the hotter the spark.
Luv the smell of NITRO in the morning.
Old 09-29-2004, 12:57 PM
batman09's Avatar
CLICK ON MY AVATAR
The msd wires I just bought are 40 ohms per foot. bm
Old 09-29-2004, 04:44 PM
Siggy_Freud's Avatar
Ah the ol' superconductors. Just did am ohms test on them after running under the hood of a Vette (and it gets hot under there) for 1.5 years. All within 40-50 ohms (per foot).
Bringing history and technology together.
Old 09-29-2004, 05:00 PM
302 Z28's Avatar
Yep, MSD 8.5mm super wires are 40 per foot.
Vince
Old 09-29-2004, 06:05 PM
suck, squeeze, bang, blow
Last journal entry: finally reeled it in
I measure with an Ohm meter and I also do a "fourth of July" test as well: spray the engine (leads) with water, shut off the lights, and start the engine. If you see fireworks like the Fourth of July, you need new leads.
Old 09-29-2004, 10:13 PM
I think the 4000-5000 ohms/foot figure refers only to carbon-core resistor wires.
Old 09-30-2004, 06:13 AM
vegahigh's Avatar
Smile
Thanks for the help, I believe new wires are in order.
Regards
VegaHigh
Old 09-30-2004, 09:40 PM
Muscle car fan
went out and checked the ones on my car 7000 ohms per foot
owch, time for an upgrade
'74 Gran Torino Project
351W, c6 trans, 9"
