sparks - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2010, 10:17 PM
sparks
i have a 85 el camino with a new crate engine n new tranny just drove it for the first time n notice something wrong went uner it n saw a spark coming from in between the motor n tranny everything is new except flywheel didnt see the screws hitting anything any advice.thanks
Old 10-17-2010, 10:56 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
It sparked when you were under the car?? Sounds like the battery connection to the starter solenoid shorted.
Old 10-17-2010, 11:09 PM
it does it when i punch it only n another thing the old motor was a 4.3 tbi n i think it had a th200 now i put a th350 n i dont know y i used the same flywheel. might that be the problem cause the spark looke like it comes from in between the torque convertor n the flexplate
Old 10-18-2010, 04:15 PM
bigdog7373's Avatar
Of course it's fast
This doesn't seem possible because the torque converter is bolted to the flexplate so there should be nothing moving between them.
Old 10-18-2010, 04:35 PM
I put a power master starter can it be wrong it's adjustable
Old 10-18-2010, 04:45 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I would be checking the wires. JMO
Cole
Old 10-18-2010, 07:58 PM
bubbahotep's Avatar
I agree with 69nova, check the starter wires they're close to the area you described. Is it possible there was an old 12v line (10 guage) going from the starter to your accessories and its now hanging there but getting power elsewhere?
Sparks and no blown fuse = bad
whats these sparks????? cutthroatkid Electrical 7 03-02-2010 09:11 PM
Sparks from engine?? carcraft69 Engine 4 07-08-2007 09:58 PM
sparks from Neg side of battery... rbomar Electrical 10 02-27-2007 08:29 PM
robert sparks rsparks100 Introduce Yourself 2 12-30-2006 12:42 PM
Sparks out of the Carburetor 71gtx Engine 5 10-30-2003 05:55 PM
