most amps have a mono setup. just hook it up throught the mono side of the amp. you do have an amp, right? if not i wouldnt get a subwoofer for the back of your car. underpowering a speacker is just as bad as overpowering it.
it has two sets of input +- on one side +- on other side |
Left, Right, and Center...
Doc here,
Check to see if your amp has "Left , Right, and Center" outputs. If so, just use the Center output in the rear middle.. In theory you should be able to "FADE" the left and right into a "Center" sounding output...I can on the vettes..but not all separation rejection is this good...just depends on your system... Doc
Aftermarket Solutions Electronic & Electrical Innovations |
you can also bridge your amp... then put the gain down...alot... do this by taking the positive from channel 1 and the negative on channel 2. some amps dont like it that much. but should be okay if you keep the gain low. i have done this many times and havent had any problems yet.
| Using Polystyrene for speaker mounts? | Jag Daddy | Interior | 7 | 11-03-2007 02:46 PM |
| speaker setup | screamin340 | Hotrodders' Lounge | 6 | 03-08-2005 02:13 PM |
| Speaker question | daimon1054 | Electrical | 8 | 02-14-2005 06:53 AM |
| speaker help | carnell | Hotrodders' Lounge | 5 | 11-24-2003 12:28 PM |
| Glueing Vinyl and Speaker Grills | Magnum | Interior | 4 | 02-07-2003 06:15 AM |
