Speaking of welders... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2009, 01:31 PM
What would be smallest amperage Mig welder for the garage? Boxing frames, brackets, etc. I don't wanna spend a lot a $$$, but I only wanna buy one.
Old 08-21-2009, 01:40 PM
life is a temporary assignment
I have the 175 Lincoln 220..Cost me around $600.00 at Lowe's..I wouldn't get anything smaller then that to do frames..
Old 08-21-2009, 02:57 PM
scrot's Avatar
Word.
Old 08-21-2009, 03:12 PM
1meancuda's Avatar
At a loss for words
Doesn't it really depend on the thickness of the material? I think the frame on my truck is 7ga, which a 110v machine would handle just fine.
Old 08-21-2009, 05:12 PM
I can only put Information out there...If you want to use it,That up to you. I would never weld any of ''my'' frame's with a 110 unit..Sorry !!!
But that how I do it,I have welded with a lot of 110 unit's, And ''NEVER'' seen one that I would weld a frame with.. My frames usually have over 400+ hp in them..And I don't recommend it..Like the old saying goes..''You can lead a horse to water,But you can't make him drink''...
Old 08-21-2009, 05:28 PM
You could safely weld a frame with a 110 machine BUT it would require some special attention and a lot of patience. First the joint would require pre-heating with a torch in order to avoid "cold starting" of the low amperage weld which would cause thermal shock to both the weld bead and the base metal, this heating of the weld area to around 400 deg. would be required before starting the weld and would have to be maintained during the welding. An even bigger problem is the short duty cycle of these machines, you are going to spend more time waiting for the welder to cool down than you will spend actually welding which can be a royal PITA both from a time standpoint and maintaining the proper base metal temperature. As I said it can be done if you are truly limited to a 110 volt welder but there is a lot more to consider than if using a bigger machine so unless you plan to limit your welding to tack welds and body sheetmetal a good higher amp 220 volt machine will work a heck of a lot better!
Old 08-21-2009, 05:37 PM
Yes!!! Your right, it can be done...But who want's to be pre-heating a frame butt to 400* ... That will sure do a frame some good... If you do pre-heat,''make sure you weld the frame to a very good jig''...
Old 08-21-2009, 06:21 PM
deadbodyman's Avatar
Wiki Edits: 11
get a used one at a pawn shop the biggest one you can get as long as it looks like new and its a miller or lincoln 110's are fine but a 220v will last longer and do anything you'll ever need out of it... a good used one runs 800.00 and a 110 ,400.00 with every thing plus gas in the tank......no gas no buy ....just saw one the other day looked brand new... plug it in and weld ...complete...400.00 listen to these guys and dont ever weld a frame with a 110v welder it'll even give a pro trouble no pros will waste thier time doing it ...yes ...it can be done ...but they wont.. they know...better
Old 08-21-2009, 06:34 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
A good welder will last a lifetime and will be used for many different things after you get one, so it seems rather silly to me to even think about getting a smaller machine and then be limited to what you can do.
Old 08-21-2009, 07:00 PM
72 grabber 51F-1 65 chevystang
I have a millermatic 175 and love it. It will do anything you want to a car or pickup
Old 08-21-2009, 07:02 PM
Very well said Mr.Henry...
Old 08-21-2009, 07:04 PM
Lost in the 60's
Wiki Edits: 4
I have had a Millermatic 160 for about 15 years now and a Solar 295 amp stick welder for 30 years. Never had a problem with either one and I have been able to do anything that I wanted to do. I always say the two most important things in your shop or garage is your welder and your air compressor...don't cheap out on either of those.
Old 08-21-2009, 07:12 PM
I'm sorry !!!! But the people that say they have a great 110, Must have never used a 220 machine.. Because if you ever did use a 220 machine, you will sell that 110 as fast as you can..There's a night and day difference... And the people that are true welder's by trade, know what I'm saying,I have been doing this for a little over 26 years, And I know some of you have been doing it longer. And to tell a man to weld a frame with a 110 is just wrong..I'm sorry.. Like Mr.henry said..This is a tool that will last a long time,if you buy the right one... I know sometime's you can't put out the $$$,,,, But just wait a little longer, And you will be much better off,And a lot Happier.. I will never tell someone to buy a 110 machine...SORRY !!!!
Old 08-21-2009, 07:16 PM
This is as true, as it get's guy's !!!!!
Old 08-21-2009, 09:18 PM
Exactly my point, it can be done BUT is it worth the effort? If all someone has is a 110, and this does happen occasionally, then there really is no limit to how thick a weld can be made with a 110 but the question is how practical would it be? With proper preheat there is no real problem with the actual weld made by the 110 machine but as was pointed out just how practical is it to preheat and maintain heat when welding a frame? The problem only gets worse as the metal gets thicker. Add to that the time spent waiting on the machine to cool to prevent exceeding the duty cycle and the advantage of the 220 is all too clear. For the occasional heavy (comparatively heavy anyway) weld then a 110 machine can be used but the extra procedure required makes it impractical for anything major.
Clarke welders bankrupt oldred Garage - Tools 38 02-25-2010 02:19 AM
For us old welders oldred Garage - Tools 12 09-22-2008 07:06 PM
HTP Welders Question for Toyman Bugs Garage - Tools 19 03-15-2006 02:19 PM
Welders mike bryan General Rodding Tech 12 01-22-2004 11:33 AM
welders and plasma cutters casper455 General Rodding Tech 7 12-18-2003 10:58 PM
