-   -   specs on 350 crate motor heads casting #93417369 (http://www.hotrodders.com/forum/specs-350-crate-motor-heads-casting-93417369-a-193310.html)
Nomad Crow 02-24-2011 08:01 PM
I want to find the specs for these heads because I'm putting them on a 305 SBC Block and was wondering the difference in specifications. Any info would be appreciated.
DoubleVision 02-24-2011 10:16 PM
33417369...90-up...350..........Gen.I Goodwrench crate motor,"Hecho en Mexico", 76cc
Placing these on a 305 would be a big mistake. The 76cc chamber will lower the 305`s compression ratio down to about 6:1 and it won`t have enough power to spin on ice. The 305 uses heads that have a 58cc and smaller chamber due to the 305`s small 3.736 bore. 305 heads are common at junkyards and machine shops, finding a set in good shape cheap should be rather easy. The 369 heads best place is the scrap pile.
