specs on 350 crate motor heads casting #93417369 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2011, 08:01 PM
Last journal entry: Frame Identity...
I want to find the specs for these heads because I'm putting them on a 305 SBC Block and was wondering the difference in specifications. Any info would be appreciated.
Old 02-24-2011, 10:16 PM
DoubleVision's Avatar
33417369...90-up...350..........Gen.I Goodwrench crate motor,"Hecho en Mexico", 76cc
Placing these on a 305 would be a big mistake. The 76cc chamber will lower the 305`s compression ratio down to about 6:1 and it won`t have enough power to spin on ice. The 305 uses heads that have a 58cc and smaller chamber due to the 305`s small 3.736 bore. 305 heads are common at junkyards and machine shops, finding a set in good shape cheap should be rather easy. The 369 heads best place is the scrap pile.
need tune up specs crate 350 gmmahieu Engine 0 01-01-2010 09:42 PM
`Crate engine casting no. Info. pepegriffo Engine 1 12-01-2009 01:43 AM
Gen I Crate Motor stevejLT4 Engine 6 11-04-2009 07:26 PM
Help with SBC 350 Crate engine ID / Specs & more 5_speed Engine 16 12-26-2008 03:58 PM
Cam Specs for a Crate Engine Sky65 Engine 1 10-20-2007 08:56 PM
