specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2003, 05:16 AM
Post specs
HELLO.need some help just bought a 84 bronco with a 351 windsor the old boy did a good job but he did not get settings right getting some detnation I.need to no the timing specs and point settings can anybody help me out . Thank you <img src="graemlins/evil.gif" border="0" alt="[evil]" />
Old 05-21-2003, 07:40 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
The points are gapped at .017, clean them by sliding a dollar bill between them, it does work.
On the timing mark where the distributor is with a marker for a referance point so you have a place to go back to at any time. Rotate the dist. 1/8" the same way the rotor turns that's equal to 3* in timing. You can power time it, rev it up and shut it off, keep backing off the timing until you dont get any run on. That should work for you. Make sure the weights are not sticking, you can rotate them by turning the rotor by hand.
Luv the smell of NITRO in the morning.
