spedo problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2004, 05:59 AM
Brian Morency's Avatar
Hauling A55 BURNING GASS!!!
Last journal entry: bros car
spedo problem
ok when im crusing and hit a little bump my spedo needle will jump around for a sec. and this happens sometimes when i dont hit a bump. how can i fix this? and that could cause this to happen
Old 10-27-2004, 07:28 AM
Restore60s's Avatar
Speedometer Jumps
More than likely if this is a cable driven system you are looking at a worn head and will probably have to go to one of the speedometer drive repair services. But I would inspect the drive gear also from the transmission just to be positive and it would not hurt to slip the cable out of its sleeve while you have the head out and inspect it also.
Old 10-27-2004, 09:38 AM
thanx
i just did a search on this site and found that it could be a loose cable? im going to check that out when i got the car up in the air next time
Old 10-27-2004, 01:32 PM
docvette's Avatar
Wiki Edits: 12
Info
Doc here
What kind of car is it?
What kind of speedo? Mechanical or digital?
Do you have Cruise control?
If it's digital, It could be an electrical problem. Or a transducer on the way out...
If mechanical, and you have cruise control you could have a bad or loose secondary Cable on the cruise control or the CC unit going out itself...or The primary Cable may be loose.
More Info please..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-27-2004, 03:23 PM
sry about the lack of info
it is a 84camaro, mechanical spedo, and no cruse control
i just got restore60's joke haha yeah i have a loose cable in my head. thats why i forgot all the info speedometer drive repair station
