Speed Demon Choke - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2006, 12:09 PM
Speed Demon Choke
My 750 Speed Demon with elec. choke
choke plate blocks sqwirter when it opens, causing the fuel shot to hit the choke plate and sort drip down into the carb.
When the plate is not blocking the sqwirter shoots directly
into the booster.
I have tried to bend the linkage to limit it with no luck.
Is there any way to limit the choke opening to stop before touching the
sqwirter?
I have also been having fuel in the manifold vac.port line that is hooked to my trans modulator if i pull the hose off the modulator fuel runs out?
Also is there any problem powering the elec. choke of the coil power lead?
thanks for your input.......
350 or 383 Stroker? my350camaro84 Engine 19 07-30-2012 08:44 AM
BG Speed Demon Choke problem malc Engine 2 02-02-2006 08:40 AM
Speed Demon choke removal commando57 Engine 20 08-23-2005 12:21 AM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
speed demon elec. choke conv. syclone Engine 5 02-16-2005 05:10 PM
