speed demon or mighty demon? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-09-2008, 12:56 PM
malc's Avatar
Living At The Speed Of Life
I did check it out before assembly.
BG and Summit need to kiss and make up, Jegs are way too expensive to use for overseas, so I´ve used Holley parts from Summit.
  #32 (permalink)
Old 04-09-2008, 01:01 PM
Again guys I got to say the one time I've messed with a BG carb and it was wrong for the application, no fault of BG's explained the situation and they were gracious to take it back for a full refund with no problems.
  #33 (permalink)
Old 04-09-2008, 06:28 PM
I still am going to buy another demon, I called prosystems today and they will let me ruturn my 950hp and are going to build me a smaller carb, but like i said I am going to get another demon just to have and compare.
So I decided to try my 625 cfm road demon jr on my 408 as I wont have a carb for a while, I was amazed as it shouldn't work good on my 408 but it idled nice and except for a small part throttle stumble ran great but after about 5 mins of driving it just stopped, I popped the hood and fuel was leaking and I noticed the front fuel bowl was filled all the way to the top and gas was just pouring into the engine, I lent it actually sold it to a friend for his 289 which had major rust in his tank, before he sold the car I gave him an edelbrock and took the demon back.......I could blame BG, but I know what the problem is........
Tech@BG why does a road demon jr run so good when I should have a "mighty demon"? Makes me think a speed demon will work just fine as it did with my 650vs speed demon.
I know duration of cam determines demon types, my int duration is within a speed demon (231.5), my exhaust duration is 2 deg's more than a speed demon (242)
Yet my cam is a custom cam that does not have a lot of overlap, is this a factor? It pulls 13-14hg at idle.
  #34 (permalink)
Old 04-09-2008, 07:17 PM
I have decided to buy a mighty demon 750 annular, also Pro-systems agreed to let me return my 950 hp and they will build me a smaller carb, 750 hp or so.
Its always good to have a "backup" I guess, After I receive both carbs I am going to tune them myself and then take my car to Superior Auto in Anaheim CA, I will have them baseline everything and then tune both carbs just for "information" Both carbs should flow similar airflow, but I am guessing they will be real close. The reman demon is under 500.00 (I'm Buying)or 549.00 new, the pro-systems was about 720.00.
I'm not doing this because I have money to burn, I really want efi but it's way more right now and I would like to post real world findings and know for myself what the results are. A lot of people bash demon carbs, some bash holleys but we are all looking for the best HP per dollar spent right?
As far as remanufactured products, I have great luck with them, they are cheaper AND have been gone thru at least twice.......
Speed Demon Available with Changeable Air Bleeds? Dino Boreanaz Engine 6 02-10-2007 11:00 AM
Speed Demon or Holley granprix76 Engine 4 04-06-2005 05:37 PM
mighty demon to big mychevystang Engine 8 02-26-2005 07:24 PM
575 speed demon Gmachine Engine 12 04-09-2004 02:20 PM
Adjusting a speed demon carb Bradless Engine 2 01-03-2003 03:29 PM
