Hi folks... Just bought a 427 BB to go in my Vette (originally a 427 and the casting numbers are correct). I'm trying to find the cam specs. All I know about it is that it's a new Speed Pro (int. - .502 292 deg. / ext. - .527 303 deg.) that his builder used.
Here's the rest of the info I have for now. Gimme some idea what I ended up with. It all looked good to me, but I'm no expert.
- Fresh build. Never installed or run.
- Professionally machined & assembled
- 2 bolt main block bored .030 over (casting #3963512)
- Cast crank reground with new main and rod bearings
- New Speed Pro cam (int.-.502 292deg. / ext.-.527 303deg.) with new cam bearings
- 10:1 forged pistons with chrome moly rings
- Reconditioned rods with ARP bolts
- New high volume oil pump
- Fel Pro gaskets
- Edelbrock Performer Intake
- Chevrolet chrome valve covers
- Pete Jackson gear drive
- Fluid Dampner Balancer
- New flex plate
- Close chamber heads are Ported and Polished (casting #3931063)
- Hardened Seats installed
- New Hydraulic Lifters
- New Pushrods
- Competion Cam Roller tip rocker arms
- New valves, valve springs, and retainers
- New Starter
- New A/C Delco oil filter
- New A/C Delco spark plugs
