speed pro forged pistons? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-30-2012, 02:05 AM
My goal was a 10:2:1, isky flat tappet 5.7 rod 400, I have the rods and pistons. But the pistons are hyper and retarded high comp ratio.
  #17 (permalink)
Old 11-30-2012, 07:11 AM
Banned
Originally Posted by F-BIRD'88 View Post
This is not true. On a drag car this is the preferred location for the fuel cell.
It is much safer under hood.
As long as it is mounted and plumbed correctly, it is fine and will pass track tech.
Be sure that the length of flexible hose that runs from the firewall to the engine
for the nitrous system is good braided steel line.
Small 1 gallon to 3 gallon upright style fuel cells that mount underhood are readily available.
Thats what they are for.
If you look, at the track you will find many drag cars with the fuel cell and fuel system all underhood
whether a nitrous car or not. Ther are many advantages to having the fuel cell and pump mounted under hood,
including safety. Including the fact that the volume of fuel onboard is much less.
Having the fuel cell mounted close to the engine negates the need for high fuel pressure.
5 to 7psi for the carb is just fine and 5 to 8 psi is fine for the nitrous system with a adjustable regulator.
The nitrous fuel system response and pressure regulation is much more consistant.
I'd like to see the rule book on this.. is it all cars or tube frame/cert. cars
  #18 (permalink)
Old 11-30-2012, 08:17 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Theres nothing in the rule book about it, other than running a ground wire for aux fuel cells.
  #19 (permalink)
Old 11-30-2012, 10:27 AM
prostreet6t9's Avatar
Differential/Driveline
Its in the rule book.. You'd have to be creative on the mounting for a stock chassis car to meet tech.
  #20 (permalink)
Old 11-30-2012, 11:08 AM
Watch Ray Commisso’s Wild, Fiery Crash At ADRL Maple Grove! | Dragzine
Granted those are cert cars and way more HP..But with way more safety gear.
Street car with Stock chassis and juice... You add the "what if" factor in.. I'd keep my fuel in the rear. There is safer ways to plump it.
  #21 (permalink)
Old 11-30-2012, 12:07 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
I'm not at all about track side horror stories because they all come about at someone else's expense.The back in the day gasser gas tanks in front of the grill are in no small part the learning curve that resulted in some of the safety rules of today.
THERE ARE NO CHEAP WAYS WHEN IT COMES TO SAFETY.Do it the right safe way the first time and spend what ever it takes...................................
  #22 (permalink)
Old 11-30-2012, 02:41 PM
1Gary's Avatar
The fuel stays much much cooler.
Using one pump is fine for the small shots.
When you get to a 200+ shot give the nitrous sytem its own dedicated fuel system.
We are not talking about a old gasser with a fuel tank hung on the grill.
Its much safer having the small fuel sell under hood.
No sanctioned track tech will refuse this system. As long as it is mounted and plumbed correctly. You guys have never been to the track.
Been racing with nitrous for 30+ years. One of the reasons why I am able to hit stock engines with big shots without trouble is correct configuration and tuning. Haveing the fuel cell under hood which allows easy use of race gas is part of that.
You just can't be taught huh.You persist even when your wrong.But when your advising someone to do something that clearly is a safety risk,I can't let that go.Been racing 10 yrs longer than you,but it doesn't take a rocket scientist to logically think taking a 5 gallon jug of racing gas to refill a fuel tank under the hood by hot headers is just plain silly.Now that doesn't account for any frontal crashes either.The worst part is you advising guys who's class doesn't require a fire suit.
Now if you find this approach a acceptable risk for you,fine.But do keep it to yourself.It doesn't make sense in so many ways.I give you my word if you ever line up against us and I find it is you,I'll protest you,and your car as a safety risk refusing to race you.We will just set there until they usher you out of the track.
I want to apologize to the O/P for these off topic posts.
  #23 (permalink)
Old 11-30-2012, 03:58 PM
Bye Jerks
none of this is true... Look at the rod stoke ratio of a Prostock engine.
5.7" rods is all yu need.
I don't even use the stream ports on my heads on my 400.
The block is plenty strong for this build.
The 400 will outperform a 350 or a 383 or a 377.
It is never better to subtract Cubic inches.
If you have a 400 block and crank, build it. With 5.7" rods.
Nitrous does not favor a long rod ratio.
I disagree with everything you said here.
The shorter rod in the Pro Stock engine lets them run a shorter deck. This gives them a better intake manifold to intake port alignment which increases HP. That's why they do it.
Empirical experience however, indicates that the mechanical stress is less with the longer rod length. There are two reasons for these results: The primary reason for these results is that the profile of the instantaneous velocity of the piston changes with rod length. The longer rod allows the piston to come to a stop at the top of the bore and accelerate away much more slowly than a short rod engine. This slower motion translates into a lower instantaneous velocity and hence lower stresses on the piston. Another strong effect on mechanical stress levels is the angle of the connecting rod with the bore centerline during the engine cycle. The smaller the centerline angle, the less the side loading on the cylinder wall. The longer rod will have less centerline angle for the same crank angle than the shorter rod and therefore has lower side loadings.
We can debate this stuff all day long. Doesn't matter.
  #24 (permalink)
Old 11-30-2012, 05:27 PM
I guess what I meant, is there a possible way to set up a old school fuel cell to work properly and safely.... Also f bird 88 on your vortec headed 400 what if u used the same combo but with ik200's? I like this form a lot more then my local one, on cc street scene everyone makes fun of gen 1 stuff there answer to any question is build a ls engine. Gee thanks dickheads lol. I've learned alot just through these past post.
  #25 (permalink)
Old 11-30-2012, 11:13 PM
1Gary's Avatar
When we used a OEM 400 we would fill the block 1/2 way to help stabilize the bores and bore and hone using torque plates.Even then the bores sealing ability would result in a different leak down test everytime.And we where running them in a N/A 9.90 class.No nitrous.
That was yrs ago and the good 400 cores where getting harder to find. You say you have a 400.Well sonic check it even with only a .030 over bore to check it for a possible thin wall and mag it for cracks. With the cooling design of the 400's you have to have the deck checked too.They warped pretty easily. I know all this stuff from yrs of racing them and from I worked at the Chevy engine plant in Tonn,NY as a engine tester/dyno rm tech.
Now for the safety aspect.I am ticked off by people through their own reckless behavior force the sanctioning bodies to clamp down on safety equipment to the extent where guys are complaining it them trying to create sales for the companies who sell the safety equipment. It costs my racing operation a young fortune to upkeep that now.But I am all about safety and I do see say N.H.R.A.'s point of view that if they didn't take a stand,there would be certain guys that would use Craigslist equipment as so to speak show and tell prevention. But worthless junk.Things like fire suits that where unraveling and 5 point harnesses that where torn.
When it comes to nostalgic racing rules,I know little about that. I would guess they are alittle more relaxed. I do remember the gasser tanks up front and if you remember that,they where mounted to aluminum frames by two spring straps.The idea was in a crash the tank would come out of the mount,but the reality was the tank came out of it's mounting and then smash on the ground or was drag by it not breaking free of the fuel line still attached to it.Not good things happened because of that.
The production Vortec's really only have a 170cc intake runner and that isn't enough for a big inch 400 SBC.It needs in the range of 195 to 200,230 cc's.The Bowtie Vortecs have a raised runner and manifold that is a 200cc intake runner that is going to get you close to what you need.Remember a bigger SBC can accept a bigger cam more easily. You would think so,but Elgin and PBR will grind you a custom cam fairly inexpensively if you call them telling them what you have and where you want to go with it.Make very sure when they tell you to use a valve spring,that is the one you use.
So to sum it up:
400's are useable if handle in the right way
I am a believer in long rod tech
Safety first no matter what rules or what anyone tells you
Bowtie Vortec heads with steam holes drilled
Elgin or PBR cams
Use their recommendations for valve springs.
  #26 (permalink)
Old 12-01-2012, 10:11 AM
hcompton's Avatar
Old & Furious
Yep you can buy bolt in tanks that fit most popular race cars. Rule book says fuel tank and engine must have firewall for most classes. Does not say they cant be the same firewall. Trunk mounted tanks are pretty dangerous. Usaly end up in with the battery and thats all bad.
Under the car is pretty safe but if it breaks in tje back and the front is on fire. You will be involed in that fire. If the front of the car is a blaze you can get out and run without crawling over a pool of burning gas. If your moving then its only a small amount of fuel and it will not cover a large area with a hot fire.
  #27 (permalink)
Old 12-01-2012, 10:29 AM
hcompton's Avatar
Old & Furious
Here is a tank that is designed for under hood mount. They make a bunch of these small shaped tanks that will fit most cars. They are pretty safe. A factory car is pretty safe for under hood fires. They spend a lot of money making sure the fire does to move to the passanger compartment quickly.
RCI 2010D RCI Drag Race and Pro Street Fuel Cells
Rod length is smoke and mirrors dyno results are minimal. For the cost 5.7 are much better option for chevy. If you had the cash you could get H beam 5.7 rods for about the same price as 6 inch I beam rods.
Sure max effort 20k motor you get the long rods. But for regular motor use the 5.7 and pocket the bucks. You will need then later. Better yet use then to buy a nice fire suit and make everyone happy!
  #28 (permalink)
Old 12-01-2012, 06:34 PM
1Gary's Avatar
Well it's like a cliff being sold because everyone else jumps off it,refills under the hood tanks by hot headers needs to be with full fire suits only or else it's a adventure.I demand anyone advising their use posts they will go to the burn unit to visit anyone anywhere if something goes wrong.
Howards stop building 5.7 cranks where you could buy the crank by it's self mainly because the 5.7 rod creates too much rocking of the piston's thrust side and that creates excessive wear.I got the very last one is why I know.I bought it as a trade off because I don't like ring spacers that 6" rods need for the street.What all of us do is build things into a engine build that adds alittle bit and all those things adds up to a final output.The topic of long rods goes back to the days of Henry"Smokey"Yunick saying "you put in the longest damm rod you can find",followed by John Lingenfelter at LPE gradually over the yrs increase the rods they use in their engines,to GM Chevy it's self increasing the rod length in it's production engines.It is well documented the positive effect a 6" rod and greater than that has.It is also follow through by the aftermarket blocks being offered.
  #29 (permalink)
Old 12-01-2012, 06:47 PM
1Gary's Avatar
But to establish a rock solid ref from this point moving forward,I believe with at 65 yrs old of a lifetime in a study in performance engines the 6" rods do have a positive effect.
  #30 (permalink)
Old 12-01-2012, 08:28 PM
hcompton's Avatar
Old & Furious
Try it for your self. Build a 383 with 5.7 rods then dyno then replace pistons and rods with 6" rods and pistons that give the same compresion in proper size for 6 inch rods.
Rods cost more and are weaker! Leverage is a fact i agree with that part.
Pistons cost more and have a less favorable pin location.
In the end your dyno results will equal about 6 hp on 400 hp engine. Total cost of about 1500 bucks over standard build. With balancing, block mods and small base circle cam along with the rods and pistons that cost almost twice the price.
Smoke and mirrors! Unless you making 800 hp it does not make a difference that offsets the cost.
lighter forged pistons (KB vs speed-pro) worth $325 on a chevy 454 Berres Engine 15 05-18-2011 09:57 AM
Which speed-pro pistons? Bucketwrench Engine 2 11-24-2009 08:08 PM
speed pro pistons ap72 Engine 7 10-28-2008 08:19 PM
What has happened to Speed Pro forged pistons machine shop tom Engine 12 11-11-2007 11:25 AM
speed pro pistons f8lpony Engine 3 01-14-2005 04:32 PM
