speed wabble at low speeds - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-04-2011, 07:03 PM
user151's Avatar
Originally Posted by user151
Too much caster can contribute, check that your caster is about 5 or 6 degrees, no more.
If no shocks, put them on.
VW used a steering stabilizer for years... wonder why?
If it starts to wobble, you can drive through it -- if it starts to wobble, hit the gas.
I'll add (based on personal experience) this is not bump steer, it is low speed death wobble.
Check your toe in, set it for 1/16 to 1/8 inch.
If your caster and toe is correct, and you have no loose parts (kingpins etc), only then add a steering stabilizer.
I had bad death wobble, added a stabilizer and it went away. But I was curious, I hadn't checked toe. So I checked toe, found it was 1-1/4" in (!!), adjusted it for 1/8" in, took off the stabilizer and went for a ride. No wobble.
I had cured the underlying problem. I put the stabilizer back anyway, but now I wasn't covering up the real problem.
Saginaw 4-speeds rj57 Transmission - Rearend 6 01-10-2011 03:39 PM
3 speeds using relays boris_thespider Electrical 6 12-11-2009 09:38 PM
IH 5 speeds kberg150 Transmission - Rearend 3 08-23-2009 06:50 PM
4 speeds turbonova72 Transmission - Rearend 3 12-06-2004 07:31 PM
New 5 or 6 speeds for old camaro? CAMARO Transmission - Rearend 0 03-01-2003 12:46 PM
