Speed wrong on speedometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2013, 12:12 PM
Last journal entry: 1952 Chevy Street Rod Truck Build
I have a rebuilt 350 turbo transmission in my 1952 street rod truck. I have an after market speedometer. I had a friend give me a new nylon gear he said fit the transmission. The speed is way to high on the speedometer as I drive. Are there different nylon gears that fit the 350 turbo. At the speedometer going 70 mph I'm actually going 55 mph according to my GPS.
Old 03-11-2013, 12:17 PM
delawarebill's Avatar
speedo
how about trying or calling a trans shop and see what they recommend for gearing..
Old 03-11-2013, 01:28 PM
Localboy808's Avatar
I have the same problem that I still havent gotten around to fixing. Th350. 3.73 gears in the rear. Someone posted a link to a site that has a calculator to figure out which gear to use if i remember correctly. I lost the link when I formatted my PC. I'm going to try and find that. If I can ill post the link.
The Following User Says Thank You to Localboy808 For This Useful Post:
NickO (03-12-2013)
Old 03-11-2013, 06:53 PM
RWENUTS's Avatar
Get a ratio adaptor to correct it.
Look here.
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
The Following User Says Thank You to RWENUTS For This Useful Post:
NickO (03-12-2013)
Old 03-11-2013, 07:07 PM
LATECH's Avatar
PATC website also has speedo calculator /correction calculator if you search it out. Better to just get the correct drive/driven gear and fix it right. IMHO
Mine has a 3.08 15 tooth drive 36 tooth driven 26.4 inch rear tires . It is spot on.
Most speedos record 1 mile at 1000 revolutions. FYI
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
NickO (03-12-2013)
Old 03-11-2013, 07:32 PM
LATECH's Avatar
turbo 350 is 1:1 in 3rd gear
You have a 3.73 rear.
Need to know your excat tire diameter on rear, or at least list the size.
with those 3 pieces of information you can figure which gears to buy and install.
NickO (03-12-2013)
Old 03-11-2013, 08:00 PM
Cape Cod Bob's Avatar
Speedometer off speed mh1984 Transmission - Rearend 8 01-08-2013 06:06 AM
speedometer cable 4 speed top loader 001mustang Transmission - Rearend 1 03-30-2011 09:37 PM
T-400 electronic speedometer / speed sensor Geterdun Transmission - Rearend 1 01-05-2011 06:57 PM
1960's 4 Speed Saginaw Speedometer problems usa3990 Transmission - Rearend 1 10-14-2010 07:08 AM
Speedometer with speed sensor on hotrod help ! dpjim2 Transmission - Rearend 1 01-08-2006 08:06 AM
