Speedo cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2011, 08:35 PM
itsandre's Avatar
Speedo cable
Hey Gang, alls runnin well here. Well almost. Having trouble with getting my speedometer to work in my 62 Impala. I have the TH350 and even with a new cable it still doesn't work. I disconnected it from the tranny and used a drill to spin the cable and it works fine but when I reattach at the tranny making sure it's key'd in it doesn't work.
Any suggestions as to what might be wrong. When I first hooked it up it worked but the needle was bouncing and then it just stopped. I bought a new cable and still doesn't work.
Old 06-13-2011, 09:44 PM
Crosley's Avatar
Wiki Edits: 1659
have you pulled the speed-O housing out of the trans to inspect the plastic gears inside?
speedo cable leakin candy63impala Transmission - Rearend 4 03-18-2010 08:46 PM
TKO Speedo Cable boris_thespider Transmission - Rearend 1 01-17-2010 11:09 PM
Mustang T5 Speedo cable DJ3100 Transmission - Rearend 2 12-03-2009 07:58 PM
Speedo cable issues IbanezPunk129 General Rodding Tech 4 08-29-2007 06:55 PM
speedo cable question.I need to know. Ken. P. Transmission - Rearend 3 04-25-2005 05:07 PM
