-   -   Speedo Cable (http://www.hotrodders.com/forum/speedo-cable-228926.html)
Charlyg 01-28-2013 07:43 PM
Speedo Cable
Hi all. Have a rebuilt '41 dash (instrument )cluster. Trying to connect speedometer to 700R4 (1986). Speedo has a female connection. is this later GM speedo connection? They might have updated the speedo when i had it redone. Any help is appeciated. Thanks.
RWENUTS 01-29-2013 08:54 AM
If nobody can hook you up then these guys can.
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
chubbie 01-31-2013 10:11 AM
i might have missed something here, is it a chevy speedo? the '41 chevy speedo has a smaller size threaded bung than the newer chevys. i used a 60's style speedo cable and used the 1941 parts on the top! the ends are crimped on. i pulled the ends off and glued them back on!
