Speedo cable blues - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2010, 02:20 PM
Vela's Avatar
Speedo cable blues
Hi Jon and all,
I'm new to rodding (although a buddy and I built a '32 Ford 3-wind coupe with a '59 Chevy 283 while we were in HS.
Now I'm old and gray and don't fit under the cars ad well. I'm retired and purchased a '23 Bucket T on a whim while in another state.
The car was registered on the road there but NJ will not register it until I have an inspection from a Street Rodder member somewhere.
Interesting Catch 22.... I need it inspected to get it on the road but I can't drive it on the road to get it inspected!
Anyway, I'm putting directionals on, stop lights and a speedometer ~ which is where my problem is.
The car never had a speedometer on it, just a tach, so I got an electronic speedometer and though I had an easy job.
First, getting the car up high enough to get under and move around was a chore in itself but that's another story.
I've looked all over the tranny ~ both sides, from the front, from the back, even asked mechanics at custom garages, but I cannot see where to screw the electronic sender into it.
I think I see a place on the driver's side but it has a metal seal down in it but it has female threads not male like my sender has...
I've lost all summer trying to get this on the road and it looks like it won't see much action until next year.
Can anyone help that has experience with the t400?
Thanks
Old 08-30-2010, 02:26 PM
poncho62's Avatar
Wiki Edits: 5
welcome.....A T400 has the speedo gear assembly in the tail housing of the tranny on the drivers side.....your electronic sender should mount there, if I am not mistaken.....
I am going to move this to the transmission forum....an expert there should know.
Old 08-30-2010, 02:44 PM
Vela's Avatar
Thank you poncho,
I looked on that tail piece but so no connections at all. I appreciate the move.
Old 08-30-2010, 03:05 PM
If you can post a photo of the sender, that will help us. The TH400 is designed for a speedo cable to attach at the rear driver's side of the case, just ahead of where the tailhousing bolts on.
Here's a photo of the speedo drive adapter installed in the trans.
Here's a photo of an electronic speedo sender in a TH400.
Old 08-30-2010, 05:19 PM
Vela's Avatar
Thanks for the quick reply Joe,
I really appreciate the photos ~ it's the first I've seen of the area.....
As you can see by my photos there is nothing but a plug in the hole
(my luck) and I also sent a picture of the sender.
Any further help will be GREATLY appreciated.
Keith
ID:	47806   Click image for larger version
ID:	47807   Click image for larger version
ID:	47808   Click image for larger version
Old 08-30-2010, 06:16 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Looks like your "sender" is meant to thread onto an existing mechanical speedo drive. Looks to me like you will need to pull the cup plug out of the dricve hole, and install a drive, then attach your electronic unit to that. Knowing what the trans and rear end were out of will help get the appropriate drive. Otherwise, hard mount a GPS unit in the dash in easy driver view, and use the speedo function on that. No cables or complec connections needed, .
Old 08-30-2010, 11:48 PM
Vela's Avatar
Thanks a lot sbchevfreak,
That GPS idea is just what I need.... it would save me a boat-load of time.
I don't know what the tranny came out of but it has a 9" rear end. I never saw a transmission without the speedometer connection on it. Odd!
I'll try to find the parts needed as I've already spent too much money on that already, but if I can't find anything in a week or so, the GPS sounds like the answer.
Keith
Old 08-31-2010, 04:51 AM
tnsmith10's Avatar
when will it rain???
Keith
odds are that the trans is out of a 4x4 and whoever built it swapped out the output shaft to make it a 2wd. when they capped off the hole for the speedo like that, the speedo usually goes into the transfer case.
now, heres the thing, your going to need a speedo housing along with both the drive and driven gears so you can hook up your electronic adapter to get a reading.
Old 08-31-2010, 06:48 AM
cboy's Avatar
Last journal entry: Finished
Having recently utilized a GPS unit as the speedo in my sedan/delivery build, I would put in a strong vote for going that route. Ebay the parts you have accumulated so far and find yourself a GPS that has a nice, large display for the speedo function. It will turn out cheaper and more accurate than your mechanical/electrical set up (since you no doubt have different size tires and a different rear end ratio which will throw off your mph and odometer readings). And on top of that, you'll have the trip planning function of the GPS for those occasions when you might need it.
Here's a shot of my Garmin showing the speedo display. The mph numbers are shown digitally within that black circle you see. They are quite visible and easy to read.
Always learning...and sharing what I've learned.
Old 08-31-2010, 07:33 AM
delawarebill's Avatar
sending unit
as mentioned above to replace it with a screw on so your new pick-up will work.. i'm using auto meter on a th350 in my bucket and works great.. and when your done, get QQ tags. hopefully its reg as a '23..
Old 08-31-2010, 11:35 AM
Keith
No biggie. It looks like someone just removed the stock speedo drive adapter and hammered in a freeze plug. Pop the freeze plug out, clean up the sealer snot, and the stock speedo drive adapter should fit right in. The adapter seals with an o-ring and is retained with a clip and bolt, as shown in the first photo I posted. Your after market speedo sender is designed to attach to the stock mechanical speedo drive gear. That sender also has an output to allow you to connect a speedo cable as well, but I guess you can just ignore that part.
Old 08-31-2010, 07:55 PM
I agree ... a easy fix ...
Here is what it should look like
( but this is a 700R4 ... the Turbo 400 works exactly the same )
You need these ...
And a gear for the output shaft.
Abot a 30 minute job ... after you get the tail housing off.
Old 08-31-2010, 09:12 PM
Vela's Avatar
Thank you all for your advice.... it is very much appreciated.
And I will say that as I've been looking for weeks for definitive answers to my problem, this site with it's knowledgeable members is the only actual information that I got that makes any sense!
I am no pro and I have very limited ability when working on this car, so I will probably go the "easy" route ~ use a GPS and eBay the other parts.
Now that I've found so many helpful Rodders, I'll have some more questions for other posts later.
Thanks again for everyone's help.... you've solved my problem and made me more informed
Keith
speedo cable problems? 77formulabandit Transmission - Rearend 1 09-02-2008 06:02 PM
How can i extend the speedo cable. 7t2HQ Interior 6 11-19-2004 04:11 PM
