Speedo cable interchange TH350 to TH400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2006, 12:58 PM
Derkyb's Avatar
Just swapped in a th400 in place of my Th350. Problem is the original speedometer cable does not fit the Th400(square hole in th400 speedo controller is bigger). I thought all these speedo cables would interchange, what can I do to make it work?
Old 09-16-2006, 02:35 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hmmm ... I think this may be an application-specific problem.
There are two common sizes for speedo-cable core wires (0.130 and 0.150) as well as a few different drive-type manufacturers (i.e. Stewart-Warner and Bendix) as well as different sized tips within those mfr's. (See guys ... they're NOT "all the same" )
Some transmissions (like mine from a 1979 C20) use a ratio adapter box which screws onto the treaded driven gear retainer, then the cable screws onto it
... while the cable threads on directly on others.
I'm not sure what your setup is like, but NAPA sells some Speedometer cable components.
Browse through these and see if you can find something that will help?
Based on your post, this is what I *think* you might need?
Part Number: BKP 615-1803
It appears to be the larger square tip for the smaller diameter cable?
HTH,
Don
Old 09-16-2006, 04:58 PM
Derkyb's Avatar
Very good info I think that may be the part I need. Thanks
How can i extend the speedo cable. 7t2HQ Interior 6 11-19-2004 04:11 PM
92' 700r4 to th350 swap speedo problem Gojo Transmission - Rearend 1 09-30-2003 10:11 PM
