Speedo Cable Leak----- - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2004, 02:46 PM
Slant3's Avatar
84 Mutt
Last journal entry: Steering column
Angry Speedo Cable Leak-----
I've seen it over and over now I am plagued with it !
How do you stop the speedo cable from leaking?(th-350)
Is there some sort of washer like you find on a water faucet or a o-ring or something???? Thanks ..
Ant.
Old 06-07-2004, 02:48 PM
poncho62's Avatar
Wiki Edits: 5
There are "O"rings...one on the housing and one on the gear shaft.
Ontario Rodders
Old 06-07-2004, 03:39 PM
Slant3's Avatar
84 Mutt
Thank you !
Old 06-07-2004, 04:24 PM
McDuff's Avatar
StreetRods Rock
I have the same problem with my 32 and replaced the gear and the O-ring type seal and it still leaked. The OD was fine. It still leaks and I put a little sealant around the O-ring seal. It now leaks just a little bit and I am not sure what to do to completely stop it.
Old 06-07-2004, 07:03 PM
Slant3's Avatar
84 Mutt
If I pull the cable back out , will it leak big time or just dribble enough for me to try and put on a new seal(o-ring)?I hate F---in' leaks. Why is there fluid by the cable anyway?(dumb question)...Thx
A.C
p.s. GO FLAMES
1 Lightning
0 Flames
end of 1st
Old 06-07-2004, 07:35 PM
McDuff's Avatar
StreetRods Rock
The gear shaft has the gear that is driven inside of the transmission and an extension of the shaft that goes through a seal. That seal along with the od seal is supposed to keep the odometer shaft dry. If you pull the odometer shaft it fits into the the gear shaft with a square end. If the seal is leaking you should be able to see where it is coming from, inside or outside. If you pull the gear shaft assembly, held by the bolt and tab, you will have a big time leak. I jacked up the drivers side of the car to get a big angle and it still leaked out pretty good. Good Luck.
I know what you mean about leaks. I try to keep the car shiny and all I get are nuisance leaks from oil, antifreeze and transmission.
Old 06-07-2004, 07:58 PM
Slant3's Avatar
84 Mutt
Thanks for the info....I will do the od seal first , since it seems to be less of a mess. Just powerwashed my driveway ,,,all nice and clean, then BAM........drip-drip-drip----better that leaks then***hold it "knock on wood" say no more !!!
Thank you !
Flames 0
Lightning 2
end of 2nd Not good !!!
