leak
Most of the sppdo housings have an inner and outer seal.
Also the speedo housing can whear out. Look for an oval opening in the houling. |
the cable haas an outer casing that was split.looked like it was coming from there. i put some 200+mph electrical tape around it to see if it stops it from leaking there. if so ill go get a new one
If you take the cable off the tranny and remove the retainer bolt and plate you can then remove the speedo gear and housing. There is a seal in the housing that is probably your problem. Replace it and the o-ring and you should be fixed up.The seal keeps oil from getting into the cable. Hope this helps.
| speedo cable problems? | 77formulabandit | Transmission - Rearend | 1 | 09-02-2008 06:02 PM |
| How can i extend the speedo cable. | 7t2HQ | Interior | 6 | 11-19-2004 04:11 PM |
