Speedo Cable leeking fluid - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2012, 12:45 AM
After connecting a speedometer cable to a Turbo 350 it started leaking fluid around the cable housing. No leaks before attaching cable, is there supposed to be an o-ring? Of course there was a speedometer drive gear in place but no leaks until I attached a cable, it's been awhile since I messed with a Turbo can't remember having this problem.
Old 01-20-2012, 07:03 AM
78 Z28 Camaro
Last journal entry: 700r4 still running strong
Yes there should be a seal,the speedo gear shaft goes thru the center of the seal.Also theirs a small steel ring that holds the seal in.You'll end up with ATF on your carpet right where your heel of your shoe rest when pressing the brake.Don't ask how I know.
Speedo cable itsandre Transmission - Rearend 1 06-13-2011 09:44 PM
TKO Speedo Cable boris_thespider Transmission - Rearend 1 01-17-2010 11:09 PM
speedo cable problems? 77formulabandit Transmission - Rearend 1 09-02-2008 06:02 PM
Speedo Cable Grommet? Riverman Body - Exterior 2 09-18-2005 10:22 PM
How can i extend the speedo cable. 7t2HQ Interior 6 11-19-2004 04:11 PM
