speedo cable problems? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2008, 11:08 AM
hi i have what seems to be a borg warner with the speedo hook up on the right side of the tail shaft...i just got a 2 piece speedo cable alittle while ago i hooked it up to the speedo turned it and it was free and regestered speed..from there i hooked it up to the second cable that i ran to my tail shaft through the shifting lever hole..i barrowed from my next door neighbor a piece that hooks up to the transmission? i have no clue what its called.. but his was from a saginaw 4 speed and it fit well..from there i finnally hooked the cable to this object that hooks up to the transmission...now the problem is it will only turn in reverse ahaha but when i put it into first and go it might spin alittle from take off and thats it..im so confused!!! and fustrated becaue i dont know the proper wording for my porblem and the object that i am using before i hook up to teh transmission with my cable.. also this is a 4 speed manaul...please some one help me...thanks mark
Old 09-02-2008, 07:02 PM
ahhahano one can hel pme at all...im going to check the dive gear for the speedo cable maybe that will work
700r4 TV Cable Problem jack71 Transmission - Rearend 7 10-25-2006 09:05 PM
700r4 cable questions bebopwally Transmission - Rearend 3 05-08-2006 05:54 PM
80 Vette Speedo Problems!!!!!!!!! SouthernRodder General Rodding Tech 6 04-24-2006 06:36 PM
80 Vette Speedo Problems!! SouthernRodder Transmission - Rearend 1 04-23-2006 05:19 PM
Speedometer problems, what is this? Nightfire General Rodding Tech 2 09-03-2005 11:17 PM
