speedo cables? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2012, 07:33 PM
speedo cables?
Are speedo cables and speedos like universal? i have a 460 with a c6 trans in an xj6 jaguar, the jaguar has a cable speedo im just woundering how i would go about setting a speedo up?
are cables universal could i just buy like a c6 trans speedo cable and plug the cable into the back of the jaguars speedo and will it work? and would it be around the same speed or would it be out by miles?
any advice and help on getting a speedo would be good =]
iv ordered water temp oil pressure and rpm gauges im just not sure how to sort out speedo..
this my first project car
Old 11-06-2012, 07:41 PM
RWENUTS's Avatar
If no one else chimes in you could contact these guys.
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
Old 11-07-2012, 04:39 AM
SSedan64's Avatar
Or check here for Info. >> V-8 Vehicle Speed Sensors (VSS), Speedometers, V8 Conversions, Stealth Conversions
Old 11-07-2012, 05:35 PM
Last journal entry: 27
i bought a universal cable from autozone and hooked it right up to my 1981 c6 and my 1940's chevy logging truck speedometer.
the nylon gear for the tranny end is color coded to give the speedo different readings.
and you can buy them on line for cheap.
everything worked just fine
Old 11-07-2012, 05:51 PM
Awesome thanks do you know how i would know what colour gear ill need to get the correct reading from my speedo?
Old 11-07-2012, 06:00 PM
i have 3'00 gears in the rear and a 28" tire
and using the brown one i am reading 5 mph fast
i figure thats close enough for the girls i go with....
Old 11-07-2012, 06:38 PM
spedo cables
check the rotation of the cabel comeing out of the 460 trans vesus the jage spedo examp. 1956 ford spedo turns op direction to 1957
Old 11-07-2012, 09:16 PM
SSedan64's Avatar
The site (RWENUTS) listed has Speedo gear calculators.
Ex: http://www.sccoa.com/faq/speedgr.html
There're also Ratio Adapters available.
http://www.transmissioncenter.org/Fo...m#RatioAdapter
http://www.transmissioncenter.net/sp...mratio adapter
battery cables corvettetonybone Electrical 31 04-07-2009 05:07 PM
Speedo Cables 123pugsy Transmission - Rearend 3 02-27-2007 01:40 PM
Battery Cables 302 Z28 Electrical 2 06-06-2004 07:00 AM
Heater Cables Travelinman Interior 5 10-24-2003 04:53 AM
battery cables 85firebird Electrical 0 06-30-2002 06:49 PM
