Speedo Error? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2010, 03:02 PM
Madmax305's Avatar
Speedo Error?
I have a 1967 El camino with a turbo 350 and a 12 bolt rear, with 4.10 gears. The rear tires are 245x50x17 and are about 26 inches tall. My speedo is way off, by about 20 mph. It could be my speedo, but does anybody know what color the plastic speedo gear should be for 4.10 gears? I don't know which one is in there now, this rear did not come stock on the Elky.
Old 02-26-2010, 03:19 PM
Well, let's see...
You have non-original tire diameter, non-original rear end ratio, and non-original trans. I can't imagine why the speedo is off...
Start here:
http://www.transmissioncenter.net/sp...n_______va.htm
Old 02-26-2010, 04:39 PM
J. E. Allison's Avatar
Originally Posted by joe_padavano
Well, let's see...
Start here:
The information you require is on the net, It is a simple fix. The easiest way to do it go to a speedometer shop and get it done. I'm sure you have one somewhere around you. It's about a 1 hour fix. If you want to do it yourself, you can do it the way I did. I actually searched the subject on the net and found a site that explained the whole thing, I fixed it and went to an interstate hwy, I drove 10 miles at 60 MPH according to the mile posts to verify it. It was perfect! Good luck! You should set the car up the way you want it before you fix it so you don't have to do it again. and you need to keep the old parts if you have a shop do it.
Old 02-26-2010, 08:03 PM
It can be a simple fix ...
While this photo is of a 700R4 ... the Turbo 350 speedometer drive is basically the same. You just need the RIGHT combination of driver/driven gears to make the speedometer read correctly.
You need a 22 tooth gear ( below ) on the shaft
and a 7 tooth gear ( shown below )
in the speedometer bullet. ( shown Below )
The local Chevrolet dealer usually has them or can get them. Or least he has for me ... in the past
1 ) remove the driveshaft
2 ) remove the bolts from the transmission mount
3 ) remove the speedometer cable, the bullet and the gear
4 ) remove the tail housing.
You should be able to see and remove the gear. Install the new gear and then reverse the steps above.
Old 02-27-2010, 09:08 AM
Madmax305's Avatar
Thanks for all the help guys, I'll let you know how it turns out...
Old 02-27-2010, 10:04 AM
Crosley's Avatar
Wiki Edits: 1659
Deuce has the plastic gears labeled incorrectly... 7 tooth on the out put shaft , 22 tooth would be a driven gear.
usually with 4.11 gears an additional speed-O corrector box is needed to alter the speed-O reading to a correct reading.
Old 02-27-2010, 10:15 AM
Madmax305's Avatar
Thanks for the update, If the speed-o box is not used, any idea how far the speed-o will be off? If it's like 5mph I won't worry about it. My speed-o is off right now about 20-25mph!
Old 02-27-2010, 10:26 AM
Crosley's Avatar
Wiki Edits: 1659
the gear count Duese gave you will be close MPH reading for your application
Old 02-27-2010, 10:31 AM
Madmax305's Avatar
OK, sounds good, thanks....
Old 02-27-2010, 01:04 PM
This is directly copied off the Raptor site.
Originally Posted by Raptor transmission
#68X. Speedometer gears for a Chevy TH350 transmission with 26 inch tires and 4.10 gears. 7 tooth drive gear and 22 tooth driven gear. Cost $22.00 for both, drive gear $11.00, driven gear $11.00. We also have 8, 9 and 10 tooth drive gears, and 17, 18, 19, 20, 21 and 22 tooth driven gears.
Go here ...
http://www.transmissioncenter.net/sp...____va.htm#350
94 caprice speedo modify hemivolvo Electrical 8 01-24-2009 07:13 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Internal server error accessing project journal AngliaBob Hotrodders Site Suggestions and Help 3 02-18-2005 11:26 AM
Speedo calibration novatech Transmission - Rearend 2 02-12-2004 07:46 PM
Jon I get an error when I go to add to the knowledge base stonedchihuahua Hotrodders Site Suggestions and Help 2 05-20-2003 10:30 AM
