speedo gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2007, 10:20 AM
Tyler
speedo gear
hi guys, i have a trans am. its got a th 350, i changed the rear end gears from 2.73 to 3.08.. what do i have to do now to get the speedo accurate??
thanks
Old 05-16-2007, 01:27 PM
You need to make the driver and driven speedometer correct for your tire and gear application. ABOVE photo shows how they work. ( but the transmission is a 700R4 ) ...
Go here for speedo calibration information.
http://www.bgsoflex.com/speedo1.html
And here ... they sell the gears and pieces ...
http://www.transmissioncenter.net/sp...____va.htm#350
Old 05-17-2007, 01:59 PM
I went from a 3.08 to a 2.73 with my Suburban (T-350), and I had to change the driven gear the same percentage less teeth. I think it was from 19 to 17.
TH350 drive gear replacement dawg Transmission - Rearend 8 04-28-2007 09:07 AM
THM speedo gear seal mhamilton Transmission - Rearend 4 02-19-2006 10:36 AM
speedo gear? f8lpony Transmission - Rearend 2 01-30-2005 03:39 PM
Roller cam/distributor gear information Jmark Engine 0 12-29-2003 03:56 PM
TH-400 Speedo Drive Gear Replacement 454impala69 Transmission - Rearend 6 03-17-2002 03:03 AM
