Assuming your brown gear is ~3/4" in diameter, the red gear has 10 teeth, and the brown one has 18. What you have is a 1.8:1 ratio, which would be used with some serious highway gears, or some seriously large tires.
With 3.55 gears, you'd need 39.8" tires to make the speedo right. Got clearance? With 26" tires, you'd need 2.32 gears to make it right. No fun in my book. Take your tire diameter and rear end ratio to www.novaresource.org/speedo.htm and use the formula to calculate what speedo gear ratio you need. Then use the chart to find what gear combos will give you the ratio closest to that. Gears are cheap at the Chevy place, or you can get them online. It's possible that the drive gear (the red one) is not firmly attached to the tailshaft itself. There's a small metal clip that holds the gear to the shaft, and if it's broken, the shaft can slip inside the gear, and the brown gear won't turn like it should. Last edited by jimfulco; 09-24-2007 at 10:42 PM. |
FIXED.
I pulled the gear out of the trans and took it to a local trans shop and told them what the problem was.I showed the gear to one of the older guys there and he said," That looks like a Buick gear".He gave me one for chevy.I got it in and it works. Jimfulco,Thanks for the link. |
| changing my spedo gear to get right after rear end swap | montea | Transmission - Rearend | 4 | 10-04-2005 03:33 PM |
| the brown wire comin from the white clip on a chevy blazer altenator?? | badk5 | Engine | 12 | 06-27-2005 08:23 PM |
| Camaro VATS ignition and column | RockinLocks4u | Electrical | 9 | 02-03-2005 09:34 PM |
