Speedo gear replacement/ Torqueflite 727 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2012, 03:23 PM
capemorgan
I am a first time user of the Chrysler 727 Torqueflite Transmission. I know that it sounds simple, but I need to change the speedo gear, so that I can get an accurate reading on my speedometer. When I unbolted it, it did not want to come out, so I was wondering if there is some procedure that I am missing. It is loose, but I did not want to force it out, and possibly break something. Any tips would be helpful. Maybe I DO need to use just a little force.
Thanks for any input.
Old 07-28-2012, 04:14 PM
RWENUTS's Avatar
If it's the adaptor with the gear on it you need to wiggle it out. It has an o-ring on it. They get sticky sometimes.
Old 07-28-2012, 05:02 PM
capemorgan
Thanks, I'll try it that way.
Old 07-28-2012, 11:04 PM
Wiki Edits: 85
Screw the cable back on, then yank on the cable. Just be careful you don't kink the cable.
The Following User Says Thank You to mmerlinn For This Useful Post:
kfmorgan (07-29-2012)
torqueflite 727 starts in 2nd Overdriv Transmission - Rearend 16 05-23-2010 11:31 PM
727 torqueflite linkage htaplymouth Transmission - Rearend 1 09-02-2009 10:53 AM
727 torqueflite engine swap question qool58 General Rodding Tech 1 12-01-2007 10:10 PM
727 Torqueflite Problem Quickhemi Transmission - Rearend 4 01-01-2006 09:18 AM
TH-400 Speedo Drive Gear Replacement 454impala69 Transmission - Rearend 6 03-17-2002 04:03 AM
