speedo gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2010, 06:30 AM
speedo gears
i hav 68 camaro i put turbo 400 in with bigger wheels and tires. my speedometer reads slower than actual mph. ive tried the charts and talked to some friends and get conficting info. i hav 2:73 rear and 26.5 dia tires with white or bone colored drive gear and black driven gear believed to be 19 and 40 teeth. i read about 20mph going 30 and gets wider the faster i go. any advise on gear set to get. frustrating
Old 11-26-2010, 08:02 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Drop the 40 tooth gear to 38 teeth.... may need a 37 , it figures close for either 38 or 37
Old 11-27-2010, 06:34 AM
speedo gears
thanks crosley, i hav both 37 and 38 tooth gears but i orderd a 18 tooth drive gear to go with it, i read that would be compatible you agree?
Old 11-27-2010, 06:58 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
your first post mentions the speed-O reads 20 when going about 30.
you need to speed up the cable rotation. A 18 tooth drive gear will slow the cable down
Old 11-27-2010, 09:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Info- http://novaresource.org/speedo.htm
Going by that, you're looking at a 18T x 37T or 38T set.
Old 11-27-2010, 09:23 AM
judd55's Avatar
I'm with Cobalt here, 18/37 combo is going to be real close, using that same chart, provided your tire dia. is correct...............
Speedo Calculator
Speedo Quit Working - 96 Chev. 4x4 S10 Racer Electrical 2 09-28-2010 04:56 PM
94 caprice speedo modify hemivolvo Electrical 8 01-24-2009 07:13 PM
SW speedo question 37fordpickup Electrical 2 12-19-2006 09:14 AM
Speedo calibration novatech Transmission - Rearend 2 02-12-2004 07:46 PM
SBC Timing Gears MI2600 Engine 1 09-20-2002 08:00 PM
