speedo gears 1953 chevrolet truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2013, 04:38 AM
hello all
Does someone know how many teeth the driven speedo gear should have from a 1953 3600 chevrolet pickup 3/4 ton with L78x 15" wheels ( or about)
I have been surfing around, but it is not that easy to find out.
Old 04-05-2013, 09:35 AM
RWENUTS's Avatar
Are you trying to correct your speedo?
Lots of info here. Use a ratio adaptor to correct speedo the easy way.
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
swap with 1965 diesel engine into 1953 chevrolet pick up bob1970 Hotrodding Basics 3 01-20-2013 08:42 AM
??? ON speedo gears 1972bigblockchev Transmission - Rearend 6 05-27-2008 04:29 PM
speedo gears sapsz28 Transmission - Rearend 4 09-18-2007 11:27 PM
power steering for 1953 chevrolet car Jeffs50ford Suspension - Brakes - Steering 4 02-19-2007 11:55 PM
1953 Chevrolet Car & Truck Specs Online khardy General Rodding Tech 1 08-22-2005 08:55 AM
