Speedo and Odometer help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2010, 11:21 AM
I had a 94 Dodge Dakota. It was the 3.9 Magnum had the 5 speed manual transmission and was 2wd. It blew up on me so I decided to make me a truck. I bought a 83 K5 Blazer rolling frame with a 305 350turbo and 203 transfer case. I took the Dakota cab off and mounted it to the blazer frame. Now I'm doing electrical. Hooking the motor up to run is no big deal i know how to do that. I need help hooking up the speedometer and odometer in the cab of the Dakota to something that will give them a reading from the 83 engine transmission and transfer case. Any help would be appreciated.
Old 11-27-2010, 11:50 AM
SSedan64's Avatar
So you need a Mechanical signal generator for an Electric speedo?
Probably have what you need here>> http://www.transmissioncenter.net/sp...n_______va.htm
Old 11-28-2010, 10:08 AM
You can also check parts for the '87 Chevy pickup and Blazer, since that was when GM went to TBI and a computer. With the computer they needed to have an electronic speed sensor somewhere in the system.
Bruce
99 mustang speedo issues. fast68 Electrical 0 04-21-2010 02:17 PM
94 caprice speedo modify hemivolvo Electrical 8 01-24-2009 07:13 PM
SW speedo question 37fordpickup Electrical 2 12-19-2006 09:14 AM
speedo and odometer not working segge Transmission - Rearend 3 03-29-2005 09:37 PM
rolling back odometer Berliner Bel Air General Rodding Tech 11 03-20-2004 02:36 AM
