speedo and odometer not working - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2005, 04:02 PM
segge's Avatar
I have a 89 mustang gt 5sp with i guess a T-5 tranny. Both the odometer and the speedo aren't working. Are these two problems interrelated, and how should I go about fixing them, mainly where do I start?
Thanks in advance for the help.
Old 03-28-2005, 07:17 PM
Originally Posted by segge
Both the odometer and the speedo aren't working. Are these two problems interrelated?
Yes they are related...........
I never had a Ford that new......... I like MINE a lot older.......But I suspect that the sensor/sender is defective in the transmission.
If it was cable driven.........I could be of more help.......
Old 03-28-2005, 08:26 PM
segge's Avatar
Please dont tell me im going to have to pull the tranny
Old 03-29-2005, 09:37 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
You shouldn't have to pull the whole thing to find out what is wrong, let alone fixing it-UNLESS there happens by chance to be something more wrong contributing to the sending unit/sensor/speedo gears not doing their job correctly.
According to a short search yours is the last year of the first generation of T-5's put into Mustangs, but I found nothing indicating whether it was a cable driven or signal sensing speedometer. Both should be easy to check if you have a repair manual for your car.
rolling back odometer Berliner Bel Air General Rodding Tech 11 03-20-2004 02:36 AM
