Speedo problems with GM T-350
I have a 1940 Ford coupe with a TH-350 tranny; the speedo quit working the other day so I disconnected the speedo shaft from the tranny and put a electric drill to it to determine if the speedo was at fault, or the tranny cable at fault. To my surprise, the speedo worked with the drill. My next step was to pull the speedo gear (yellow) out of the tranny and it appeared to be in good shape so I removed the drive shaft and disconnected the tail shaft housing to examine the (orange) speedo drive gear. It too looked to be in good shape. I replaced the end seal and put all back together and test drove the car, with no speedo registering. What to do now?
Speedo problems
Thanks all. I am off to Advance Auto to purchase another seal and dissasemble the tail shaft again to re-inspect the gears....something is just not right.
speedo drive gear
Finally found the problem....the retainer pin that holds the speedo drive gear onto the tail shaft was split
(broken) and allowed the gear to move just enough so that the speedo gear would not engage.
| Turbo 350 speedo help. | BigRoy1978 | Transmission - Rearend | 4 | 12-07-2009 08:41 PM |
| speedo cable problems? | 77formulabandit | Transmission - Rearend | 1 | 09-02-2008 06:02 PM |
| Speedo Problems | T fortwo | General Rodding Tech | 3 | 11-20-2007 06:07 PM |
| 80 Vette Speedo Problems!!!!!!!!! | SouthernRodder | General Rodding Tech | 6 | 04-24-2006 05:36 PM |
| 80 Vette Speedo Problems!! | SouthernRodder | Transmission - Rearend | 1 | 04-23-2006 04:19 PM |
