Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 05-08-2008, 03:17 PM
Red neck blazer Red neck blazer is offline
Giverhell and hopefer the best
Speedo Q
I dont know if this is in the right place or not so if it ant then sorry.But a few of yall have said that if my speedo is off then it will show crap fuel mileage. And i know that mine is off by bout 10 mph. So what it ant easy cheap why to fix the speedo. Thanks fer the help yall.
Old 05-08-2008, 03:36 PM
F&J F&J is offline
re: Speedo Q
Easiest way is not cheap. That would be to figure out how much in %, and then get a 'speedo adapter" gearbox. Takes less than a minute to install.
More work, but cheaper is to get the correct "driven" speedo gear. If you get lucky, you may not need to change the drive gear which is more work. You won't know until you find out the exact error you have in %, and then find out what drive & driven gears you have...then go to GM and they can look up the corrections. They may prefer you give them your axle ratio, tire size, etc, instead..
Way too much screwing around for me. Just ante up, and buy the adapter
By the way, you can't just say my speedo is off by 10. Get on a hiway with mile markers and compute the percentage.
Old 05-08-2008, 05:13 PM
Chevrolet4x4s Chevrolet4x4s is offline
 Chevrolet4x4s's barnstar
re: Speedo Q
Old 05-08-2008, 07:24 PM
jimfulco jimfulco is offline
re: Speedo Q
http://novaresource.org/speedo.htm has a formula that uses tire diameter & rear end gear ratio, and a chart of speedo gear combinations.
http://tciauto.com/Products/TechInfo/speedo_gears.asp has a tire diameter calculator.
Old 05-08-2008, 07:27 PM
poncho62's Avatar
poncho62 poncho62 is offline
Moderator
 poncho62's barnstar
Wiki Edits: 4
re: Speedo Q
If you know you are 10% off, just factor in that 10%.....There, it cost you nothing......That will be 29.95 for the advise.................
Old 05-08-2008, 08:49 PM
Speedo Q
Thanks fer all the heop guys.I had no idea that it would be that envolved to fix that thing.But it will be a long project so i ant in to big of a hurry on something that small.Thanks agian.
Old 05-09-2008, 05:07 AM
F&J F&J is offline
re: Speedo Q
It's not really involved or difficult
When I recalibrate a build, I just go out on the highway here that has mile markers each mile. I go 10 miles. Let's say after the 10th mile, I have gained 1 mile too much on the odometer...that means you need to slow down the speedo cable approximately 10%. Then just get the 10% reducing adapter. I also use a watch with a second hand, to time each mile, or just hold it at a steady 60mph for those 10 miles, to see if the error is the same on speed, as well as "miles driven".
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Speedo Q"
Speedo replacement Lilcarrin Hotrodding Basics 1 07-30-2007 06:45 PM
SW speedo question 37fordpickup Electrical 2 12-19-2006 08:14 AM
Gotta get new speedo...need help! Nightfire General Rodding Tech 2 08-23-2005 07:50 AM
Speedo calibration novatech Transmission - Rearend 2 02-12-2004 06:46 PM
Speedo not working..4spd Trav Transmission - Rearend 5 07-31-2003 12:21 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
