thanksSpecial thanks to our top 25 hot rod how-to article editors:
Powerrodsmike, Techinspector1, Oldguy829, Chevythunder, Crashfarmer, Schnitz, Alittle1, JerryMopar, LowRollerChevy, Blazin72, Docvette, Chevrolet4x4s, Paulmeisel, 48 Dodge, Pigjamelectric, Inventor, Triaged, Slowride66, Pepi, 427v8, TooMany2count, Topfuel, Arrowhead, Lbell101, Crashtech.
Create hot rod how-to articles in the Crankshaft Coalition Wiki. See a list of all articles, start a new article, or see the 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Hotrodding Basics
  #1
Old 07-30-2007, 04:58 PM
Lilcarrin's Avatar
Lilcarrin Lilcarrin is offline
Speedo replacement
I ordered a new Speedo cause my old one went out ..
so here is the question .. since i want to leave everything original .. i want to mount the new Speedo under the dash .. would you guys get a new Speedo wire or take the one from the original Speedo ?
and on top if i get a new one how much work am i looking to install the hole story
Thanks
Old 07-30-2007, 06:45 PM
techinspector1 techinspector1 is offline
Senior Curmudgeon
 techinspector1's barnstar
Wiki Edits: 103
re: Speedo replacement
Assuming the speedo cable operates off the transmission, there is only one outlet on the tranny, so if you're asking can you leave the old cable there on the tranny and run another one, no.
Just unscrew the old cable from the existing speedo and screw it onto the new one, leaving the other end of the cable attached to the tranny like it is now.
As to how much work it will be, don't know. How involved do you want it to be? I mean, it's pretty simple, not like an engine swap or something.
You will want to make sure though, before you go to all the trouble of buying and installing a new one, that it isn't the speedo cable itself that hasn't self-destructed. Unscrew it from the speedo and hold the end of it where a passenger can see the little square drive cable turning inside the housing. If it isn't turning, it's the cable or the drive gear in the tranny that's fragged.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Speedo replacement"
TH350 drive gear replacement dawg Transmission - Rearend 8 04-28-2007 08:07 AM
SW speedo question 37fordpickup Electrical 2 12-19-2006 08:14 AM
Speedo calibration novatech Transmission - Rearend 2 02-12-2004 06:46 PM
Speedo not working..4spd Trav Transmission - Rearend 5 07-31-2003 12:21 AM
TH-400 Speedo Drive Gear Replacement 454impala69 Transmission - Rearend 6 03-17-2002 02:03 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
