Speedo wiring on T56 trans? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2012, 01:46 PM
staleg's Avatar
Last journal entry: Hand brake
I have an electric speedometer that I'm not sure how to wire to my T56 trans,
It's an Aurora/AutoLoc speedometer. I know it's low quality China stuff, but that's what I have for now. The Auto Loc mounting instructions only show how to wire against a 3 wire hall effect sensor, but as far as I have understood, the T56 transmission don't have a hall effect sensor, just a 2 wire VSS sensor...?
Here's what their instructions says:
So how du I wire the two VSS wires to the Speedometer?
My suggestion:
-red wire from the speedo to +12V
-black wire from speedo spliced in 2 with 1 wire to ground and 1 to VSS.
-White wire from speedo to VSS.
Does it matter which of the two VSS wires that goes to ground? The VSS pigtail has GM correct yellow and purple wires.
I have tried the AutoLoc customer support, but they didn't understand my question at all. Is it me that's in the fog here?
Old 08-01-2012, 03:46 PM
bigdog7373's Avatar
Of course it's fast
Call the transmission maker. Tremec is it? They will be much more helpful than the speedo company.
Old 08-02-2012, 12:17 AM
staleg's Avatar
The transmission is from a LT-1 Camaro.
Old 08-02-2012, 10:04 AM
bigdog7373's Avatar
Of course it's fast
T56 speedo sender wiring - Team Camaro Tech
See if this guys response helps at all.
Maybe someone else will chime in here. This isn't my forté
Old 08-03-2012, 01:45 PM
staleg's Avatar
Thanks for the link! Now I've got something to start with.
Trans/Speedo convert. DoubleVision Transmission - Rearend 4 08-29-2011 06:48 AM
wiring reverse lockout solenoid for LT1/T56 tylerwerrin Electrical 3 01-15-2011 05:21 PM
Swapping from A4 to T56 -- can anyone help with wiring? tylerwerrin Transmission - Rearend 1 01-12-2011 04:17 PM
Wiring a T-5 (Electronic) to a new speedo 40pickup Transmission - Rearend 0 09-09-2008 06:45 PM
electronic speedo wiring sparkyct55 Electrical 1 07-23-2008 02:34 PM
