speedomeeter gear 350 turbo - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2014, 08:12 PM
im having problems with my speedometer gear / driven gear to wear out? I have a 350 turbo and my speedo cable wont turn because the driven gear is wore out. so i replaced it with a new one and tested it in the car for a few minutes. result were the cable still didnt turn unless i pryed down on gear housing. so pulled driven gear back out and it was chewed up on one side all the way around. so does the problem lie with the drive gear? my drive gear is a 10 tooth and the driven is a 19 tooth.
Old 07-22-2014, 11:21 PM
Wiki Edits: 85
Originally Posted by dstief View Post
..., so does the problem lie with the drive gear?
Probably..
Old 07-23-2014, 06:42 PM
so today i took the tail housing off the trany to replace the drive gear. i removed the drive gear and find that the clip that locates the drive gear is broken allowing the drive gear to be pushed to far forward . causing the two gears to not seat properly. so i replaced the clip and problem fixed.
Turbo 350, will not downshift into low gear fleetmitch Transmission - Rearend 0 08-07-2011 08:50 AM
Turbo 350 dropping out of 3rd gear aoz28 Transmission - Rearend 1 06-18-2008 08:45 PM
Turbo 350 skipping 2nd gear matty_torana1978 Transmission - Rearend 0 10-24-2007 05:31 AM
350 turbo tranny / first gear badriand Transmission - Rearend 3 10-12-2007 08:42 AM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
