Hi: Thanks for the question. I am moving your post to General Rodding Tech. I think you will get more and better answers there.
Dan
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
WELCOME to Hotrodders.com What type of vehicle are we talking about ? Lots of older vehicles had a mechanical speedometer drive ... with a cable. The cable sometimes needs lubrication ... and sometimes the speedometer head needs attention ... |
See if the cable is kninked any where or frayed. If it looks good remove the inner drive cable and clean it up and lube it lightly with a light grease such as Lubri-plate. Don't lube the last 8 inches or so at the speedo head.
Or just replace the complete cable with a new one. gcrmcc |
I've had a similar problem in a couple of cars and it turned out to be the plastic speedometer gears in the trans. What happens is that the speedo cable wears and puts additional drag on the plastic gears. The gears eventually wear out, causing the slippage. Since the gears have trans oil on them, you usually get hydraulic coupling at slower speeds (sort of like a mini torque converter) but as speeds increase the gears just slip. Replace the cable AND the gears.
The speedo driven gear is easy, since you get at it by simply removing the retainer on the side of the trans. The speedo drive gear is on the output shaft of the trans (except for the 200-4R transmission) and requires the tailhousing to be removed first. |
http://www.redrider.us/Speedometer_Gears.htm#350
for a look at the inside and to get parts |
| Recent General Rodding Tech posts with photos |
| Electric Speedometer Senders | oldcarguy36 | Electrical | 10 | 05-08-2010 02:53 PM |
| speedometer with its own mind???? | Old School Nut | General Rodding Tech | 15 | 06-06-2008 04:10 PM |
| Speedometer | fred56 | General Rodding Tech | 5 | 01-17-2007 02:25 PM |
| Help Speedometer Not Working (at all) | phebbler | Transmission - Rearend | 7 | 08-01-2006 01:13 PM |
| Speedometer Information. | M&M CUSTOM | Transmission - Rearend | 0 | 04-03-2005 08:47 AM |
