speedometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2008, 01:56 PM
untchable502's Avatar
speedometer
not sure if this is a tranny question or not, i have a 82 chevy camaro with a mild 350 and a th-350 bolted to it, i put a new speedometer cable on and went to a junk yard and found a nice mechanical speedometer out of a new camaro, my problem is is that the needle jumps around and i'm not excactly sure what speed i'm going is there any way to fix and calibrate that or just get an electrical on thats you can calibrate, will the electric one do the same thing????
Old 05-05-2008, 04:33 PM
31 five window
Last journal entry: grill and rear end
If the needle is jumping on a mechanical speedo it is usually the gear on the tranny end of the cable. Disconnect the cable and run it with an electric drill. If it runs smooth it is not a problem from there to the speedo. Pull the gear out of the side of the tranny and you will probably see teeth missing or badly worn in one spot. Replace the gear.
Electric Speedometer Senders oldcarguy36 Electrical 10 05-08-2010 03:53 PM
speedometer with its own mind???? Old School Nut General Rodding Tech 15 06-06-2008 05:10 PM
Speedometer fred56 General Rodding Tech 5 01-17-2007 03:25 PM
Help Speedometer Not Working (at all) phebbler Transmission - Rearend 7 08-01-2006 02:13 PM
Speedometer Information. M&M CUSTOM Transmission - Rearend 0 04-03-2005 09:47 AM
