speedometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2010, 06:23 AM
speedometer
Hi! I have a question, I change the wiring in my 93 Camaro to a 95 wiring to have a more tunable computer and is using the 700r trans instead of the 4160e how do I get the speedometer to work. Thank You!
Old 10-22-2010, 04:15 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site. If you post your question over in the transmission-rearend or electrical section someone will help you out. Not everyone checks the intro section.
Cole
Old 10-22-2010, 09:48 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the electronic speed-O parts can easily be installed on the 700r4 trans.
Reluctor wheel onto the out put shaft, install the electronic VSS unit into the tail housing hole... plug the Camaro harness connector
56 Chevy Speedometer Calibration issue oldchevy1956 Transmission - Rearend 4 07-06-2010 05:27 PM
Electric Speedometer Senders oldcarguy36 Electrical 10 05-08-2010 02:53 PM
2004 Silverado electric speedometer Deuce General Rodding Tech 8 10-28-2008 07:04 AM
Help Speedometer Not Working (at all) phebbler Transmission - Rearend 7 08-01-2006 01:13 PM
Speedometer Information. M&M CUSTOM Transmission - Rearend 0 04-03-2005 08:47 AM
