Speedometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2003, 01:43 AM
Speedometer
Can someone tell me how to fix the speedometer in my 1981 grand prix? The mileage doesn't even work.
Old 11-16-2003, 01:54 AM
BstMech's Avatar
NYOFP4RJ3CHRIS
Check the cable first, disconnect it from the rear of the tranny and spin it while having someone watch the speedometer (go both directions). If the speedo rises at all while spinning the cable, pull the gear out that the cable attaches to and check it. If the gear is bad you will have to change both gears as a set or you'll be changing it again soon if you just change one.
If the speedo doesn't move while spinning the cable, pull the middle out of the cable (remove the cable from the housing) and make sure it's not broken (still has both square ends). If you can't pull the cable out of the housing, disconnect it from the speedo end and have someone hold one end from turning. You shouldn't be able to turn it from the other end.
Old 11-16-2003, 07:09 AM
Tazz
Sounds like BstMech has it covered. First thing I thought of was a worn out cable or stripped gear., the inside will strip out and the cable will spin inside of it. You didn't say how many mile are on your ride. A high mileage car might have the cable disconnected at the spedo, sometimes the spedo will whine real loud and disconnecting it is the only way to stop the noise. Be sure the spedo is connected at both ends, just a thought. Remember to tell us what you find , makes it all worth while, don't ya know!! Also a learning experience for us all.
Todd
Rat Rods Rule!
Old 11-16-2003, 08:38 AM
does autozone carry the gears?
Old 11-18-2003, 08:40 PM
Gettin a life..Goodbye
I think the gears are a dealer item. Be sure to take the old one with you. They need to count the teeth and get an exact gear. They are cheap and plentiful. I had a whole bunch of them when I was trying to calibrate my truck to a new rear end.
Old 11-18-2003, 09:55 PM
Rubberman2003's Avatar
AS they said, the gears are very specific, i took mine to a Tranny place and he had some extras (he gave me some ) what a cool guy. I guess the rear ratio/tire size/tranny, they all matter, make sure you know all those things.
Old 11-21-2003, 05:06 AM
I got tired of foolin around with that gear stuff. I bought a VDO electronic speedo for my truck. You just install the head and screw the sending unit on the transmission where the cable goes then drive down the highway hit the button to calibrate it. No more guessing and you can recalibrate it if you change tire size, tranny gears, or rear end ratios.
