Speedometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2003, 10:16 PM
69 chevelle SS's Avatar
Speedometer
Hey guys, my chevelle has the stock speedometer in it and at about 85-90 my needle just starts flopping around between 90-120(peg). Is there any way i can fix that or is that just bad design in the gauge?
Old 11-19-2003, 10:28 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Powdered graphite lube should fix the problem. This means taking the speedo out of the dash to apply it.
Old 11-20-2003, 06:42 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I would consider properly lubricating the speedometer cable itself first.
The bouncing needle is a good indicator, and besides it's much easier than removing the speedometer.
Old 11-20-2003, 11:22 AM
How would i go about lubricating the speedometer?, just disconnect it from the transmission and spray up it, or pull it from the back of the gauge or am i totally off on both?
