-   -   speedometer (http://www.hotrodders.com/forum/speedometer-91659.html)
88chevy 06-13-2006 10:50 PM
speedometer
i just installed a speedometer on my tranny its a 700 form a 1988 chevy and it wont work the speedometer has an electrical connection can neone help!!
tnsmith10 06-14-2006 06:45 AM
check the fuses under the dash 1st, if all is ok, then check the wires that go to the v.s.s. (vehicle speed sensor). i have seen the wires melted together b4... local dealer should carry the pigtail in stock...
theres more that it could be, but that would be a good place to start.
and b4 i forget, why did u replace it? was the speedo already not working? was it leaking? more info please.
Jmark 06-14-2006 09:18 AM
Need to clarify something. Does the trans have an electrical connection? or does the CAR harness have an electrical connection? Makes a difference what the fix is.
Mark
88chevy 06-14-2006 03:23 PM
i replaced it cuz the stock speedometer was like magnetic or something and the gear for the speedometer is plastic on the tranny i just put in, and i put in a speedometer that is driven by a gear and has the same connection from the truck to the speedometer
