speedometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2006, 10:50 PM
speedometer
i just installed a speedometer on my tranny its a 700 form a 1988 chevy and it wont work the speedometer has an electrical connection can neone help!!
Old 06-14-2006, 06:45 AM
tnsmith10's Avatar
when will it rain???
check the fuses under the dash 1st, if all is ok, then check the wires that go to the v.s.s. (vehicle speed sensor). i have seen the wires melted together b4... local dealer should carry the pigtail in stock...
theres more that it could be, but that would be a good place to start.
and b4 i forget, why did u replace it? was the speedo already not working? was it leaking? more info please.
Old 06-14-2006, 09:18 AM
Jmark's Avatar
Need to clarify something. Does the trans have an electrical connection? or does the CAR harness have an electrical connection? Makes a difference what the fix is.
Mark
Old 06-14-2006, 03:23 PM
i replaced it cuz the stock speedometer was like magnetic or something and the gear for the speedometer is plastic on the tranny i just put in, and i put in a speedometer that is driven by a gear and has the same connection from the truck to the speedometer
speedometer with its own mind???? Old School Nut General Rodding Tech 15 06-06-2008 04:10 PM
T5 Speedometer question. M&M CUSTOM Transmission - Rearend 3 02-22-2006 05:59 AM
Speedometer Information. M&M CUSTOM Transmission - Rearend 0 04-03-2005 08:47 AM
chevelle speedometer repair stinky jinx General Rodding Tech 2 02-16-2005 04:23 PM
700R4 - Speedometer chev38 Transmission - Rearend 10 05-06-2004 08:00 PM
