Speedometer Cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2011, 04:20 PM
40P10
Speedometer Cable
I'm trying to replace my speedometer cable in my '56 Ford Mainline that has a three speed transmission. My problem is that when I re-insert the cable and gear into the transmission it doesn't want to seat. I don't want to force it in so does anybody have any help on what might be the reason it's not seating or binding. Everything has been cleaned and looks OK and I have not put it on the Speedometer head. Cable is laying free on the ground so no binding above. Any help?
Thanks
Old 02-13-2011, 05:59 PM
justold's Avatar
Try turning the drive shaft and inserting the gear at the same time .
Old 02-13-2011, 06:04 PM
sqzbox's Avatar
My pipes are my music
If there is a new O-ring on the gear housing it may need some Vaseline to help it into the tranny. Have you tried rotating the cable from the speedo end? it may take several attempts to mesh the driven gear on the end of the cable into the drive gear in the tranny. That's about all the idea's I have
because that's the only two problems I've ever encountered. Hope this helps.
Old 02-14-2011, 12:20 PM
40P10
Speedo Cable Insertion Problem
will give your ideas a try...also....how loose is the gear to cable? Mine seems to fall off the cable as I withdraw it from the tranny. That means fishing it out a bit with needlenose pliers so's I can grab with the old fingers. Back at ya if things don't work
Old 02-14-2011, 03:56 PM
Don't the gear have a groove in it? That is for the clip to hold the gear on.
OLDROD
Old 02-14-2011, 06:27 PM
40P10
Speedometer Insertion!
Finally got the sucker in! Vasolined up the seal and looked like every thing lined up; got the rear up and turned the gear a it; put the speedo end in and "Pushed" that last little bit with gusto. Thing popped right in. Guess I was a bit leery of giving it a good shove but that's what did the trick. Was just enough to do the job but not enough to break anything. To those who responded...THANKS for the time and ideas.....
Old 02-15-2011, 04:11 AM
sqzbox's Avatar
I had a girlfriend like that once. Thanks for the memories!
speedometer cable yragat General Rodding Tech 8 04-13-2008 04:17 PM
speedometer cable stea Hotrodding Basics 9 07-13-2006 01:01 PM
speedometer cable leak th 350 matt_ramsey Transmission - Rearend 8 11-20-2005 07:41 AM
lost speedometer cable tiedoe Electrical 1 08-01-2005 03:41 PM
Speedometer cable noise stinky jinx Transmission - Rearend 3 03-24-2005 12:23 PM
