speedometer cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2006, 07:43 PM
stea's Avatar
speedometer cable
Im trying to hook up the cable between a TH350 and a dolphin mechanical speedometer. All cables I have looked at have some type of slip fitting on the gauge end but I need a cable that screw onto the speedo housing. It looks the same as the tranny fitting but a smaller diameter.
Anybody else run into this? If so, what cable did u use?
Old 07-10-2006, 08:05 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Have you checked with Dolphin about getting the proper cable for your application? www.dolphingauges.com
Old 07-10-2006, 09:20 PM
stea's Avatar
I emailed them but havent heard from them yet. Just checking to see if anybody else had run into this problem.
Old 07-10-2006, 09:55 PM
Classix_Lover's Avatar
Music soothes the soul
Last journal entry: Wiring finished finally
Yea, I ran into that problem when I was attempting to get my speedometer working. You're probably going to have to order the kind with 2 screwable ends because everywhere I went, they only had one end that screws into the housing on the tranny and one that snapped onto the guage. Luckily, I had the old cable hidden and tucked away so I got that to work.
Old 07-10-2006, 10:39 PM
stea's Avatar
Classix, what was your original cable out of?
Look at cables made for older cars and trucks. I don't know about all manufacturers, but Chevy didn't start using the slip-fit ends until the late '60s or thereabouts.
Old 07-11-2006, 11:51 AM
64 el camino
Old 07-11-2006, 01:46 PM
stea's Avatar
I knew I should have just went to NAPA in the first place. 2 minutes and I was out the door with the right cable. Thanks for the help.
Old 07-11-2006, 01:50 PM
rj57's Avatar
You should be able to buy this type of cable at any NAPA. Maybe even the Zone or Advanced?
I have to use this type with my '57s.
Old 07-13-2006, 12:01 PM
While you guys are on the speedo cable subject - I looked at a mid 80's Ford Ranger with a Turbo 350 trans - no speedo cable. Does anyone know if the slip style on the back of a Ford speedo is the same as a GM and vice versa?
Daytona Speedometer Electric Cable Dee Cercopely General Rodding Tech 2 10-18-2005 03:01 PM
Speedometer cable noise stinky jinx Transmission - Rearend 3 03-24-2005 11:23 AM
