Speedometer Calibration - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2003, 06:13 PM
67 Nova 400sbc.4L60
Post Speedometer Calibration
Question on a 1991 Camaro with a 4L60 Trans if you change the rear gears to 3.73 What procedure do you follow to recalibrate the speedometer.
Old 05-22-2003, 05:44 PM
DoubleVision's Avatar
Post
http://www.tciauto.com/tech_info/speedo_gears.htm
This is what I used to get mine back in correct working order.
Old 05-22-2003, 05:54 PM
Post
Some of the late model GM transmissions have a electric speedometer drive. My 90 Silverado did.
When I changed the rear end ratio.....the speedometer was OFF. It had a chip with 5-6 legs off each side. I found a chart that told (GM service manual) which leg up and which leg down was the correct configuration for the gear I had installed.
I believe the 91 Camaro was that way also.
3.73 is a factory offered gear SO I know it is a simple matter to correct
Old 05-23-2003, 09:54 AM
67 Nova 400sbc.4L60
Post
Thanks "Doublevision" #5093 for the speedo cable charts ,I'll savethose for future reference.However this model uses a reluctor (toothed rotor) and an electromagnet speed sensor. Also Thanks "Deuseroadster" #3897 I have a 1991 Siverado GM manual and I found the push/pull set up. My buddy with the Camaro Says he can't find it next to his ECM and the Dealer said they couldn't help him.What I would need to know is what the Camaro Manual says. Thanks.
