Speedometer calibration - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2005, 08:47 PM
Jimmy Neutron's Avatar
New Member
I have a 1970 Camaro with a TH 350 transmission.
I have changed the rear gears and tires and want to calibrate the speedometer.The speedometer is KM.
4.10 gears
tires 255/60r15
drive gear 7 teeth
The formula said I should use a 21 teeth driven gear.
My problem is that the car is originaly equiped with a reducer between the speedometer and the transmission and I don`t know the ratio.
Can I use the formula and use the 21 teeth driven gear?
Old 09-03-2005, 12:50 AM
Reducers I have seen have had the ratio stamped on the outside. It's usually stamped very lightly, so it's easy to overlook.
Old 09-03-2005, 04:02 PM
New Member
Today I have put the 21 teeth driven gear in and the Speedometer worked great.
thanks for the reply
speedometer with its own mind???? Old School Nut General Rodding Tech 15 06-06-2008 05:10 PM
Speedometer Information. M&M CUSTOM Transmission - Rearend 0 04-03-2005 09:47 AM
calibration for a speedometer CurtisL Transmission - Rearend 3 11-17-2004 02:09 AM
speedometer calibration jum Transmission - Rearend 2 01-17-2004 05:41 PM
Speedometer Calibration paul poirier Transmission - Rearend 3 05-23-2003 10:54 AM
