Speedometer conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2008, 01:24 PM
Minace21's Avatar
Ok i have two 700r4 transmissions ones stick speedo ones mechanical the mechanical is shot to hell and i dont feel like putting the money up to rebuild it but the stick speedo is fine but i need to find a way to convert it to mechanical can anyone help?
Old 02-11-2008, 01:47 PM
WELCOME to Hotrodders.com
It is fairly simple to change over, especially since you alrady have one with the mechanical speedometer setup.
Here is a photo of the 700R4 speedometer drive for a cable drive speedometer. Pull the little bullet from the tailhousing after removing the small bolt and clip that holds it in place.
Then remove the tailhousing
Then you will see the driver gear ...
Remove the small clip and slide the gear off the shaft.
REVERSE the installation on the other transmission ... I strongly suggest you buy two new gears ... the driver gear and the gear that goes in the bullet.
Electric Speedometer Senders oldcarguy36 Electrical 10 05-08-2010 02:53 PM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 09:06 PM
Help Speedometer Not Working (at all) phebbler Transmission - Rearend 7 08-01-2006 01:13 PM
Speedometer Information. M&M CUSTOM Transmission - Rearend 0 04-03-2005 08:47 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
